Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Why does my iPhone 4s keep turning off after a replaced battery?
I have had my Iphone 4S for about 20 months and last week it started turning off on it's own on and off. At first when the problem started, it would work no matter what when plugged in but then that wouldn't even work. When that started to happen I bought a new battery and replaced it but the problem never changed. The phone will turn on but when it turns on the apple logo is on the screen for about a minute then practically immediately after turning on and going to my lock screen it shuts back off on its own. The phone is out of warranty so it can't be replaced by Apple. Please help!!!!
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
I have a similar sounding issue. The forced power on trick helps me kick start the phone but then it keeps rebooting at random but short intervals.
I've tried a couple of different batteries and have previously swapped the dock connector but I don't think these are related.
Can anyone recognise the symptoms and suggest what the issue might be please
Was dit antwoord nuttig?
Score 1
Hi Wyatt,
Just ensure that your iPhone is connected to DC input or has enough battery.
Try normal power-up:
Press the power/standby button and hold it there for a few seconds
If you tried the above for about 5-10 seconds but nothing happened, then try to force iPhone power-up.
To force it to power-up:
Press the Home button, hold it there, followed by the power/standby button, and hold it there when apple logo appears.
Hope it was helpful.
I have the same exact problem! I had my screen replaced by a telephone repair place so Apple refused to help. So I got another repairer to replace the battery, but to have it happen once more again. My phone would shut off at even 94% battery. The only way I could start it up again would be to plug it back into the wall to jump start it. Then, once it went back to lock screen, it would shut down again.
Will try the above process when it happens again.
I have similar issues but it doesn't turn off it just screens off and on after the timeout. so it'll be off, then randomly the screen shows then if I leave it sit for 30 seconds or whatever the screen goes back off and it just does this repetitively. It doesn't power on and off, just screen turns on and off....any ideas anyone?
Voeg je antwoord toe
wyatt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 11,459
