Ga door naar hoofdinhoud
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 Vragen Bekijk alle
Vraag afgerond
Problem with SSD MacBook Air A1304
Hi,
I have a problem with formatting SSD in MBA A1304.
I installed a new SSD (Samsung), went to Disk Utility.
SSD is visible but when I try to partition it, the process is never finished.
I checked this SSD on other laptop (Win), it works good, both partitioning it and formatting were success.
I checked the other HDD cable against my MBA and result is the same - partitioning is frozen.
So, both SSD and hdd cable are good.
What could be the reason? Motherboard?
Did anyone faced with the same issue?
Thanks.
Update
I use original MBA A1304 SSD Drive!
Please see my first post:
Any other useful ideas?
Is dit een goede vraag?
3 opmerkingen
Oleg - Just to be clear here you are using the original SSD that came with your MacBook Air, correct? I think what got us confused here is you stated you have a new Samsung SSD not the original SSD (or HD) the system came with. If on the other hand this is a new Samsung SSD then the issue is within the SSD or its' connection not the system its' self as you can get it to see the SSD.
door
Can you take a picture of your SSD so we can see the labels & chip markings. I'm thinking you have a SATA II or SATA III device Vs the needed SATA I.
door
Are you able to setup a USB connected flash drive (partition, format & install the Mac OS onto it) on this system?
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
The issue has been resolved. The prob was in SATA controller on logic board.
Was dit antwoord nuttig?
1 Opmerking:
I replaced motherboard.
door
Het nuttigste antwoord
Did you get the correct SSD?
Is your MBA the A1237 model which has a PATA (ZIF) HD/SSD, and you got a SATA drive by mistake?
If you have one of the A1304 models the SSD needs to be a 1.8" SATA I (1.5 Gb/s) drive. In addition Apple has two different versions of ribbon cable as the HD vendor changed the type of connector on the HD/SSD's to a different type. So you do need to make sure you have the correct drive for the cable your system has or replace the cable to correctly mate to your HD/SSD.
Here's the IFIXIT Guide HD replacement guide
Score 2
You could use the partitioning from the laptop where it works - just choose GUID. You might be trying to run a SAT III SSD on a SATA I machine - in that case you have to drop the transfer speed, or, replace the drive.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,978
