Ga door naar hoofdinhoud
The RIM BlackBerry Curve 8520 is a sleek entry-level smartphone that delivers some nice design enhancements and great performance
20 Vragen Bekijk alle
x on the signal bar with any sim card
with original sim card or any other sim card there is an x on the signal bar, so i am presuming that the signal receiver is broken. i have opened up the backberry and im looking at the chasis or the motherboard. Where is the signal receiver and what does it look like?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Couple of things:
First, I read your previous question and I'm not convinced it is an antenna fault. However, to answer your question the antenna looks like this and costs about $2.00.
Second, I believe, if it is a hardware issue, that it may be the SIM card reader itself. If that is the case you may need a new logic board.
Third, the little "x" in the signal area usually means that it is still actively searching for a signal, but is not in range of one. So it is possible that since you were changing settings for unlocking the phone that it is searching for a signal that is is out of range of. If this is the case it means your hardware is all perfectly fine and you have a software (settings) issue.
Was dit antwoord nuttig?
Score 1
hello i have cell phone blackberry curve 8520 icant type keyboard thank you.
Voeg je antwoord toe
kayleigh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 534
