Ga door naar hoofdinhoud
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Vragen Bekijk alle
Upgrade Core 2 Duo 3.06 GHz to a newer I Series CPU?
Hi, I've a 4 year old iMac with a 3,06 GHz Core 2 Duo processor. I would like to know if it's possible to upgrade it to a better one like a i3, i5 or i7. Has anybody done this upgrade?
Thank you
Dario
Is dit een goede vraag?
Score 5
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
There is no possible upgrade path here, sorry ;-{
Intel never offered a pin compatible LGA775 socket i3, i5 or i7 series chip. The systems architecture is very different.
The only option which I think is going overboard here is to swap out the logic board with the iMac 27" 2.8 GHz i7 (Late 2009) logic board. Given the amount of work and price of a new logic board, I think you would be better off with a newer used system for the price.
Was dit antwoord nuttig?
Score 4
I found this same problem on an older post from IFIXIT, looks like they were asking about the same model. Here is the link to the problem, in the answer Mayer posted a link to a guide on how this can be done: iMac27 dual core 3.06 2309 CPU upgrade
Hope this helps
If you purchased i5 or i7 logic board for the same model, you could upgrade the iMac to i series.
Rundown of the different CPU's and there sockets:
  • Core 2 Duo & Core 2 Duo Extreme (quad) - Socket: 755
  • i3 & i5 1st gen - Socket: LGA1156
  • i3 i5 2nd & 3rd gen Socket: LGA1155
  • i7 1st gen Socket: LGA1366
  • i7 Extreme Socket: LGA1366
Score -1
1 Opmerking:
You have some errors here. I would recommend referencing this site:
- Intel Core i3 processor families
- Intel Core i5 processor families
- Intel Core i7 processor families
As a better reference
door
Voeg je antwoord toe
Dario zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 44
Altijd: 15,710
