Ga door naar hoofdinhoud
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Sticking track pad button
is this trick valid for Macbook Unibody (white) too? Reference to this question Trackpad click button is jammed
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I don't recommend the WD-40 trick as it will only make a mess. The oil in it will act like a magnet collecting the dust and debris around your system.
While its some work you can take the track pad out and clean it properly and make sure it's OK (and if needed carefully lube the pivot-point).
The root issue is something either is jamming it or something was spilled onto the click button.
Lastly, the battery could have swelled-up pushing on the trackpad from below.
Was dit antwoord nuttig?
Voeg je antwoord toe
visoyah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 259
