Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
White lines on iPhone 5 after screen replacement
Hi there
I just replaced the screen on an iPhone 5 the second time and there are still vertical white lines coming up across the whole screen. Not sure if it is a bad connection put I cleaned it and made sure its connected properly. According to my supplier it is an issue with static in the phone?
ANYONE ANY IDEAS?
Thanks
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
dissconnect and reconnect. be sure its is seated properly, if so, bad screen
Was dit antwoord nuttig?
2 opmerkingen:
Thanks. Do you think there could be issues with static? We did hundreds of screens but never had issues like that. And on 2 separate screens on one phone
door
nothing to do with static i think. we probably have the same supplier ;-) they tell me the same thing.
they'll try everything just so theyt dont have to pay you back..
door
Take no notice it is a handset problem probably bad processor I'm an iphone tech over 10y seen this lotts of times, u wont find an lcd that will work I promise u
2 opmerkingen:
iPhone hasnt been around 10 years
door
Rubbish! Works with old cracked screen
door
@ Danny so if that is the case why didn't I have this problem with the old cracked screen?
In the broken screen .... touch screen work?
This failure usually stems from the connection of the contacts screen touch screen.
The best way to check this is to take the original screen from another phone and to put it on the phone... To isolate the problem
Voeg je antwoord toe
chris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 11,389
