Ga door naar hoofdinhoud
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 Vragen Bekijk alle
Camera Shutter Stuck After Screen Replacement
I recently replaced a broken screen and now the back camera shutter is stuck. I tried a new back camera, but that didn't fix it. I also tried a hard reset, but that also didn't work. Ay ideas how to resolve the issue? Could the connection not be right?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I figured it out. I removed the camera, erased and reset the iPad, ran the set up process, and then reinstalled the camera. Then everything worked.
Was dit antwoord nuttig?
Het nuttigste antwoord
Some loose connectors between cameras and the logic board. Reseat every connector in between, especially the front camera which is easy to come off
Score 1
Voeg je antwoord toe
Boss77 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 10
Altijd: 262
