Will isopropyl alcohol be safe on my lcd monitor?
Have some adhesive on my lcd from peeling off the glass component, will isopropyl alcohol be a safe solvent to clean it off?
Is dit een goede vraag?
Make sure you get a good quality alcohol as some cheap stuff has other solvents which can cause damage or it leaves a film of junk when it dries. Best to get 85% or better, reagent grade being the ideal (no junk in it).
Wet a cotton swab with the alcohol. Don't over do it, as you don't want the alcohol is seep into the works.
Was dit antwoord nuttig?
I agree with everything but the percentage you mention. For cleaning things like this or electronic boards use Pharmaceutical grade 91% or better. If you can't find it on the shelf the pharmacist will have it behind the counter or you can by it on line. I realize that you are thinking there is not much difference between 85% and 91% (available at Walgreens) but, there is insofar as contaminate content. I use 99% for things like this, final clean on boards and in my flux formula.
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 10,900
