Ga door naar hoofdinhoud
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Vragen Bekijk alle
White Plastic around charge port is broken and iPod won't dock.
Theres a piece of white plastic that surrounds the charge port on the Ipod. Half of the plastic broke off on mine and now the speaker dock won't detect it when docked. I can still connect it to the USB cable however. Does anyone know if this white plastic piece can be replaced?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
The broken plastic is most likely what allows/forces the connection to stay just where it should be. A cable/USB cable doesn't have the same problem as it's made to fit snug at any angle.
You may need to either find a replacement casing for the ipod, or put something on the dock that it can lean onto to be pushed back to where it should be. It only needs to be a tiny amount off center to not be able to work properly.
Was dit antwoord nuttig?
Score 1
Blake, the plastic bezel part is available at places like this and many others. Hope this helps, good luck.
Score 1
Voeg je antwoord toe
Blake zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 239
