Ga door naar hoofdinhoud
1.6, 1.8, or 2 GHz G5 processor
20 Vragen Bekijk alle
Grey screen with file with question mark on it
My 2005 imac has a grey screen with a question mark on it. whats wrong with it and how do I fix it?
thanks JS
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Try booting up with the grey recovery disk you got with the system and run Disk Utility you maybe able to save the drive, but you may need to reformat the drive and install a fresh copy of the OS.
Otherwise you'll need a new HD as Machead stated. Given the age of your system you may want to think about a newer new or used system to replace it.
Was dit antwoord nuttig?
Het nuttigste antwoord
No boot drive (Operating System) found. Generally indicates a thrashed HD. Replace the HD install the OS.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Voeg je antwoord toe
Joey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 187
