Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
Back camera not working anymore
Hi, I had to replace the power and sensor cable. By doing that I killed the display cable so I had to replace it as well.
After replacing the two things I realized that the rear camera is not working anymore.
If checked the contacts and the gold bracket, but all seems to be in well condition. I also couldn't find a broken camera cable.
Tried hard-reset. All other hardware operations are working except rear camera and led light.
Also tried to restore the whole device.
Any suggestions?
PS: The gold bracket is between case and logicboard? And not above logicboard?
Update
Today I got the new camera and replaced it.
But it doesn't work.
Any other suggestions to do or to check?
// Front camera is working when I'm using facetime.
Update
The U10 component (http://www.moulnisky.com/downloads/Apple...) seems to be a little bit damaged. Do you think that could be the reason?
How to remove the U10 component from the logic board?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Hello,
The gold bracket should look like this when it is installed correctly.
This might effect the cameras operation so ensure this is correct before we go on to anything else.
If you have confirmed this bracket is correct and the camera still will not function then i suggest replacing the camera, seems like you haven't had much luck on this one. This guide will help you through the replacement (not like i think you need it).
Please let me know how you get on and as always if you ever need any help just ask.
Cheers
Brendan Mills
If this Answer is helpful please remember to return and mark it Accepted.
Was dit antwoord nuttig?
2 opmerkingen:
Hi I rechecked the gold bracket and it's installed correctly. I just ordered a new rear camera. I'll keep informing you if it helped changing the camera.
door
Same issue. Bracket was in place correctly.
I tried replacing the camera, still no go. Anybody find a solution?
door
Hi , I seem to have the same problem and did everything possible. I even replaced the camera too. So with all that said hopefully my fix will be your fix. I called Samsung direct and they told me to send it to them. Not being in warranty the cost was $70.00. I will let you no if that works when I get it back in 7-9 days :(
1 Opmerking:
This post is about an iPhone problem. If your phone is a Samsung, it would be better to delete your answer as it is misleading to people looking for an iPhone answer
door
After replacing my power cable my rear facing camera & LED stopped working as well. I took a Q-tip dipped in rubbing alcohol and wiped down the gold contact and metal camera surface. My camera and LED started working after that.
Voeg je antwoord toe
Matthias zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 4,036
