Ga door naar hoofdinhoud
Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Vragen Bekijk alle
logic board replacement Got 2.4 want 2.66
Hi i have a faulty logic board with 2.4GHz processor and have found same board with same graphic card puled out of same macbook but it has got faster processor 2.6GHz. Will it fit?
Thanks Marcel
Is dit een goede vraag?
Score -1
1 Opmerking
Hard to tell as it depending on the series it came from, if it is then it should work, otherwise it's highly unlikely as the location of the mounts, connections and/or the fan are likely different.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I have once been given a 2012 MBP to repair with the casing completely damaged beyond use but the logic board was okay, I stripped down an old 2009 MBP and fitted all the items from the 2012 into the 2009 and yes it fitted, there was one screw mounting point which was not the the right place but this did not effect the operation of the logic board.
In short it will fit as all A1278 model MBPs are design with the same fitting apart from that one screw position, which is near the display cable BTW.
Follow this guide to show you how to fit the new logic board.
Let me know how it goes and as always if you need anymore help please just ask.
Cheers
Brendan Mills
Was dit antwoord nuttig?
Voeg je antwoord toe
marcel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 10
Altijd: 212
