Ga door naar hoofdinhoud
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
no display or backlight
Ipad 2 back-light or LCD not working. unit was not dropped. I have sound because it lets me know i have email. digitizer works, i will swipe my finger where you unlock and it makes the unlock sound. I attached to my tv via hdmi accessories cable and ipad displays on tv. not sure if it is logic board issue or needing new LCD. Please Help
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
i had a repair on iPad 2 recently, in that case it was weak connection between LCD and LCD cable, had to clean it and reconnect. It worked fine.
But there is also many other possible options can be as well:
1) bad LCD
2) water damage
3) problem with motherboard (backlight filter and some other ICs)
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thanks Vlad, I will check the LCD cable to start.
door
Voeg je antwoord toe
Kevin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 913
