Broken logic board LCD connector
Hi, I am having some major trouble. It seems as if the socket on the logic board to connect the lcd is broken. The retainer gold bracket that goes over the socket has fallen off. The plastic on the socket also seems to have broken off. Is there a fix for this without buying a new logic board please help
Is dit een goede vraag?
2 opmerkingen
Could you upload a pict showing the damaged connector and then we may be able to give an accurate answer.
door lemerise
I have the exactly the same problem as Holger.
I have a degree in electronics, so I could replace the connector on the main board, if I knew what it was called.
Anyone knows?
door Kristoffer Amundsen
