Ga door naar hoofdinhoud
Can I add ram? Increase speed?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
You can't increase speed but you can add memory (one slot) to 640 Mb (Apple) or 1152 MB (Mactracker). I don't know what memory you have now but the computer has 128 MB on the board so to reach Apples limit would take a 512 Mb memory stick and the larger ammount would take a 1 Gb stick. The memory is PC2100 DDR266 200 pin SO-DIMM. Ralph
PowerBook G4 Aluminum 12" 867 MHz RAM Replacement
Ifixit sells PC 2700 memory for this unit--it is backward compatable.
Was dit antwoord nuttig?
Score 1
I put a 1 G chip into my 12" PB, 1.33 GHz. Got the chip off Amazon, fairly cheap if I remember. I think it was about 38 bucks plus shipping, less then 42 bucks total.
I also put a dual layer burner into it also. It runs great, even running Leopard.
Voeg je antwoord toe
dsover zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 1,470
