Why are my contacts not syncing correctly between iPhones and iMac?
I have entered new contacts in certain "groups" into my personal Mac at home but the newly entered contacts will not transfer to my phones (yes, I have 2), and neither has the edited versions when I have synced them. Could the problem be, that my computer is not updated to the current software? I have Snow Leopard now
Is dit een goede vraag?
9 opmerkingen
iCloud can offer hand to [url=http://www.recovery-ipad.com/transfer-co...]sync contacts from iPhone to iMac[/url]. If you have contacts synched via iCloud, then login to icloud.com and then go to the contacts page. Select all the contacts you wish to import (you can even use Cmd-A to select all), then click the cog icon in the bottom left corner and select Export vCard. Once exported, open that file and it will ask you if you want to import it into Contacts on your Mac.
door minaliamill
I also have the same problem, how can do it?
door Careuuosly
You can try Gmail to sync your iPhone contacts to iMac.
door Jackrouslly
Maybe you can use the iPhone Transfer for Mac, which can be used on the Mac. And the iPhone Transfer is a tool that can transfer data including contacts, music, photos and more between iPhone and Mac. Here is the guide you can follow: how to sync contacts between iPhone and PC/Mac.
door AdolfNicoll
Still didn't work Minaliamill
door lordieshepherd
4 commentaren meer tonen
