Changing tailgate key lock cylinder
I have a 2003 Tahoe wich must be very similar to the suburban . My tailgate door key lock is jammed. I can not even enter my key in. Where to find the part and what is the procedure to change it
Is dit een goede vraag?
1 Opmerking
Have you first tried spraying it with WD40 or other penetrating oil? What type of climate are you in snow & wet or dry & dusty? When I lived in New Mexico I had to spray and insert the key slowly deeper in repetitively into the lock to dislodge the grit until I could get the key fully in. The key slot guard most cars have was missing (or jammed open) so the wind drove the grit into the lock.
door Dan
