Ga door naar hoofdinhoud
Repair information for the 4th Generation iPod shuffle. Released in September of 2010. Model number: A1373.
31 Vragen Bekijk alle
What's the cable pinouts?
i have been looking for the pin-outs of the ipod shuffle 4g cable for a day now, and i can't find anything correct, only the 2g witch is apparently not the same one as the 4g. i really need help fast. just to make it easier for you to answer i included a picture, so if you know it please answer
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Valen S, one of the things to remember is that the Shuffle 4G has a few IC's of unknown type as part of the cable, so we are not sure yet of exactly what they do and how they impact the cable. The pinout itself is as follows ( I am using your markings)
iPod pin 4 to USB pin C => USB DATA - / Left Channel
iPod pin 3 to USB pin B => USB DATA + / Right Channel
iPod pin 2 to USB pin A => GND
iPod pin 1 to USB pin D => Vcc
Hope this helps, good luck.
Was dit antwoord nuttig?
Score 4
4 opmerkingen:
hmm, weird that nobody has ever taken one apart. the ic stuff is probably a way for apple to earn money :(
door
Yup, that is what makes those cables special and costly ;-)
door
Thanks, guys!!!
door
Did the correct pinout get you comnected or is the PCB necassary to establish a connection?
door
I have found a PCB with several CMD electronic components like IC's, capacitors and resistors inside USB connector of iPod Shuffle 4g cable.
Score 1
2 opmerkingen:
Hi im making a homemade cable so is it posible to make it witouth these components? please answer ASAP Thank you
door
Did you do it??
door
Voeg je antwoord toe
Valen S zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 100
Altijd: 17,398
