Ga door naar hoofdinhoud
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
157 Vragen Bekijk alle
Why my controller doesn't connect to my PS3?
I spoiled water on my controller and then the arrows were not working. So I open it and cleaned it up but now, it won't connect to my PS3.. the LEDS keeps flashing and flashing...
Could you help me ?
Is dit een goede vraag?
Score -1
6 opmerkingen
How did you clean it? Did you check the components while you cleaned it?
door
How I do ? i already tried to reset the controller and its not working with the USB cable ...
door
all the components are fine they have no breaks or anything
door
yes, I was wondering how you cleaned it.
door
with a scott towel
door
1 commentaar meer tonen
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Nicolas, any time you have any electronic component being exposed to water you are running the risk of shortcircuiting any component. I suggest you totally disassemble the controller, after that soak all the components in high grade, preferably anything of 90% isopropyl alcohol. this will displace all the water that may have collected under any of the components. Air dry it after and re-evaluate. Do keep in mind, that just because the components look okay, their internal function may have failed. Not every short circuited component shows external damage. Scott Towels are great for gross contamination, but most certainly not for the microscopic one.
Was dit antwoord nuttig?
Score 1
you may need to re sync it to the console.
Voeg je antwoord toe
Nicolas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 859
