Ga door naar hoofdinhoud
Device repair and troubleshooting manuals for fixing accessories made for Nintendo's numerous video game consoles.
Screw driver to disassemble the wii nunchuk
Does anybody know if the driver for the diy 54 bit driver kit will fit to remove the tr-wing screw on the wii nunchuk?
If not is there a recommended driver I can purchase from ifixit?
Thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hello
The tri-wing screws used in the Nintendo Wii are Y0. This bit is in the 54 bit driver kit, but you can buy this screwdriver alone too.
Here are the links:
54 Bit Driver kit: http://www.ifixit.com/Tools/54-Bit-Drive...
Y0 screwdriver: Tri-point Y0 Screwdriver
Similar to a Phillips, but with 3 blades. Precision fixed blade screwdriver engineered by iFixit. Afbeelding
Product
$5.49
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
excellent. I did end up getting the 54 bit driver kit however i was worried that on the wii nunchuk it would be too narrow for the driver from the kit to fit. Can anyone confirm this? Thanks!
door
In case anyone else is looking for this answer. The Y0 in the 54 bit driver kit is too wide. The tri-point Y0 standalone screwdriver however worked perfectly.
Thanks.
door
There a guide here (Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly) which says "Tri-point #1". Is this a mistake?
door
Voeg je antwoord toe
Jase1516 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 5,775
