Ga door naar hoofdinhoud
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Vragen Bekijk alle
NFC: This Tag Is Not Supported
Hi, whenever I try to scan my new NFC tags that my sis got me from eBay with my S4, it says "This tag is not supported" on 3 different NFC writer apps! I even tried to scan one outside of any app with the same result! Help?
Is dit een goede vraag?
Score 24
1 Opmerking
It works. Thanks. :)
door
Voeg een opmerking toe
12 Antwoorden
Het nuttigste antwoord
Go to swipe menu you get when you swipe the home screen down ( so you can turn on bluetooth and wifi and all that) then turn off nfc tag! It stops the annoying bleeding beeping that drives you crazy everytime you move the poxy thing..................and breathe
Was dit antwoord nuttig?
Score 16
11 opmerkingen:
Perfecto!; Mine was under settings, 'Connect and Share' NFC - swipe to off position.
door
Thanks so much for your help!
door
Thank you. I even use a galaxy S6 for this issue you solved.
door
This is about the only answer that was right
door
Thank you! You saved my life
door
6 commentaren meer tonen
http://www.themobileindian.com/news/1186...
Samsung's flagship smartphone Galaxy S4 has been incompatible with the first generation TecTiles Near Field Communication tags. Now the company quietly plans to push the TecTiles 2 NFC Tags.
Score 2
1 Opmerking:
thanks it was driving me mad
door
I get the same message on my main screen when I move the phone. Please let me know what causes it and how to stop it when you know.
Score 2
Thank you! Thank you! Thank you! Thank you!
Was driving me loopy..
Score 2
Thanks for the fix too. But what is nfc tag and how did it turn itself on?
Score 1
How do I fix this when I need NFC on to work my smart gear Watch?
Score 1
Whatis NCF tag I have got
Score 1
i can not use this my nfc tag is not working
my nfc keeps beeping on my samsung galaxy s6 keeps beeping i wanna have it on but i dont want to turn it off what can i do to make it stop beeping
You can just turn off the sound. But the best way is to turn off NFC
What is NFC tags and what is it used for???
I had my hotel card/key in my hand and this kept beeping! I googled the code to figure-out what it was and lo-n-behold, it was the key!!
Voeg je antwoord toe
Jeremy Scalpello zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 24
Altijd: 85,732
