How to set up sharpness on GoPro Hero3?
How to set up sharpness on GoPro Hero3 Black Edition lens? How to turn off a lens? It repents is pasted?
Is dit een goede vraag?
I don't think you can change the sharpness in the settings as best as I can tell.
Was dit antwoord nuttig?
I not meant that. How to sort a lens to set up focus, it at me is baffled.
I apologize as I do not understand your question. I would recommend reading the manual. Here.
Revision PS... I have seen a new video that does demonstrate removing protective plastic rings and twisting the lens 3.5mm. I really felt uncomfortable twisting the lens and didn't want to damage the plastic around the lens. Naturally the video is provided by someone selling replacement lens. I think the below tip may still apply.
After a water dunking I had an internal smudge on the lower left of every picture and video.
When I tore it down I also used another video found on YouTube that appeared to show removing the lens (untwisting) from a mount on the circuit card with a pair of pliers... I attempted that.
After my attempt I don't think the lens is twistable, adjustable or removable from that mount expect for the four corner screws that hold the lens to the sensor. There is quite a bit of padding between the sensor and the lens. I think you might try to see there is a difference between a few turns of the screws that hold the sensor to the lens. There is quite a bit of adjustment between gently snug and tight.
Give that a try. Hope that helps.
Jack Z.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 1,545
