Ga door naar hoofdinhoud
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
How to remove small scratches on the retina display?
After owning many Mac laptops, I must say the Retina display is VERY sensitive to scratches. I take good care of my stuff and I still wonder how it happened (never happened before). Anyway, I got two scratches (like tiny holes) on the display. I tried to buff one out and it did not help, since it made it glossy and the display is mate. I thought of using a resin, like the ones used to repair cracked glass on cars, but I would like to know if someone have used it before.
Is dit een goede vraag?
Score 12
16 opmerkingen
Hi Denis,
Did you get anywhere with this as I've just put a tiny scratch on my screen :(
door
Sorry guys, I did not find anything to fix the scratches.
door
Guys things wont stay new.. Everything get scratches after time you use it so its normal, if you dont want scratches on your devices put it back in the box and never open it again.. I have a few scratches too they are there so get over it, it doesnt make your macbook un useble.. Buy a screen protectorext time..
door
"Guys things wont stay new.. Everything get scratches after time you use it so its normal, if you dont want scratches on your devices put it back in the box and never open it again.. I have a few scratches too they are there so get over it, it doesnt make your macbook un useble.. Buy a screen protectorext time.."
Troll - Most useless comment ever. If you don't have constructive advice don't bother commenting.
door
11 commentaren meer tonen
Voeg een opmerking toe
8 Antwoorden
Gekozen oplossing
Car resin is made for car glass. You don't scoop ice cream with a shovel just because it works as a scoop. Therefore, unless it is explicitly stated that the resin is safe to use with computer glass, don't use it. I found this for you: http://www.877geeksonsite.com/computer-r... Try using the methods the site suggests. Good luck!
Note: If this answer helped you, please mark it as a solution! Thanks.
Was dit antwoord nuttig?
Score -2
9 opmerkingen:
I already tried the toothpaste. Since the retina display is not shiny, I ended up with a shiny spot on my mate screen. I'll see about the epoxy and post something here if it works.
Thanks!
door
Toothpaste is made for teeth too...
door
The question is about a soft screen and the answer is about computer glass. Not really proper.
(I tried to vote no but was told I had not enough points...
door
hi there i had problem with my screen and scraped every coating up to the glass on my MacBook pro retina dis. now the screen is white and i can't see anything i took the dark coating pieces and close up to the screen and i can see what is the dark coating on those screens? i have also 3d glasses and i can see perfectly in them but when off the screen is white any suggestions???
door
super careful how did this screen get scratched
door
4 commentaren meer tonen
Het nuttigste antwoord
https://youtu.be/4UpWfmpETg0 - video instruction.
He used PolyWatch Polish
Score 4
I have now had three... THREE retina displays.
The first time I had tiny cracks like pinhead cracks in a cluster in the middle of the screen. The second screen had a dead pixel. The third I cleaned today and noticed two small pinhead sized cracks again.
I have no idea how this happened... I take very good care of this, especially since the first incident. Each time it was replaced by Apple Care but that has now expired. I have a THULE case and now I'm thinking that the only way to resolve this in future is to get a screen protector.
How did everyone else's happen?
2 opmerkingen:
@james holdman: I thought the warranty doesn't cover accidental physical damage :I have a pinhead dent on my screen which has resulted in 2 dead pixels. My mac is less than a month old :( I have no idea how it got there and applecare told me that the warranty doesn't cover physical damage (including scratches) even if it wasn't intentional.
door
This thread is A bit old but still relevant. My answer to how the pin head scratches or chips happen is the MagSafe 2 power connector. If it ever smacks onto the screen or the case of MacBook it will chip it very easily. It's not hard to do because the thin rubbery cable can swing around when handling it. The hard metal edges of the connector do the rest. I think it's the only design flaw of the otherwise fantastic mbp. I have 3 chips on my case and twice have I had tiny chips on the screen. Very annoying for me today because I just had the screen replaced.
door
I have a patch of small scratches at the top left of the display where my thumb touches when I open the top or adjust it. My previous Pro had a glass screen and never had a mark despite heavy useage.
I used to repair scratched CDs with car wax. The wax fills in the microscopic scratch marks and buff to a shine. Sometimes, I had to use a cotton-tipped applicator to rub the wax into the scratch so that it would be completely filled in. Visually, the scratches disappeared. And the previously unplayable scratched CD could at least be played long enough for me to make a copy. Car wax might work with laptop screens as well.
Man I have the same thing on my brand new 2019 MacBook Pro 16”, I am crying here it’s not even a month old and there is a small pinhead dent like a few pixels small… I have genius appointment and will see what they tell me.. I wish this happened within the 14 days so I could just have it returned without any questions lol
3 opmerkingen:
YES! This same thing happened to me on my new 16 inch macbook pro and I am absolutely mortified. Just SO SO SO glad to not be the only one with this issue. I have babied this thing like nothing before. I really think its a design problem if a speck of dust can scratch the screen just by closing the %#*@ laptop
door
please let me know what Genius said if you see this comment
door
Sam here. Bought in November 20. Now like you saying guys a 1-2 pixel small hole scratches all around the screen. ALWAYS USE MICRO FIBER CLOTH TO CLEAN THE KEYBOARDS BEFORE CLOSING DOWN but still the holes coming day by day more and more..... WHAT GLASS IS THIS? just close down a screen and the glass melt under dusts what is impossible to avoid????? 4000 USD laptop..
door
I reckon Apple is doing this on purpose; making the screens super fragile - since the retina hardware is basically future proof until the advent of quantum computing - I noticed after a year of use that even the keys created 100s of micro scratches from when the lid is closed...... UNREAL - Apple Care replaced it citing "problems with the display coating"; there were many other scratches too from when wiping the screen - just got it back and installed a Kuzy screen protector - it makes the screen matte and is fantastic, really like it and it reduces glare - it makes my retina pro feel like my 17 pro w matte - now I can clean the screen without destroying it within 2 months of having a new display - sorry guys but this is what happens with this new age mac products..... they have quality issues all around....
Score -1
Have you tried using a little bit of Vaseline or toothpaste and rubbing it in the effected area? It helped me on my desktop monitor.
Score -2
5 opmerkingen:
is yours a retina display?
door
&&^& your deskstop computer.....you know that idea is not going to work...and its going to make it worst
door
Next time use a 100 grit sandpaper it will make less of a mess! Really don't use anything on your screen you'll just make it worse! Vaseline is grease so dust & grit will collect and then when you wipe the screen you'll scratch it! Toothpaste (or sandpaper) is not much better here all you end up doing is damaging the anti-glare coatings.
door
Its the spray on or film apple uses.
door
loved apple since the 80 now hate them
door
Voeg je antwoord toe
Denis Savard zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 68
Afgelopen 30 dagen: 344
Altijd: 206,705
