Ga door naar hoofdinhoud
Battery instead of optical drive?
Can I remove my DVD drive and add battery instead of it to my MBP? Thanks
MBP 17" Core 2 DUE late 2007
Update (04/13/2010)
Thanks all, I think i will get my DVD drive out and replace it with a HD.
Is dit een goede vraag?
Score 1
1 Opmerking
Thanks for your reply, now since you said i can add a HD instead of my optical drive ( which i use 1 every 6 month ) where can i find the steps to do that? Thanks again
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hi! That's a great idea, but unfortunately there's no way to do that. You can add a second hard drive instead of the optical drive, because a hard drive uses the same connector as the existing optical drive, but adding a second battery would require wiring and electronics that just don't exist in the computer, and as far as I know, no one has taken this on as a project.
Was dit antwoord nuttig?
Score 2
Here's the guide for replacing the optical drive: MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement
Here's the optical bay adapter for use in another drive: [gekoppeld product ontbreekt of is uitgeschakeld: IF107-078]
Here's a SSD drive that might be of interest: http://www.ifixit.com/Mac-Parts/MacBook-...
Score 2
2 opmerkingen:
Great research. +1 Ralph
door
Thanks but i'm looking for 17" not 15" !! not sure if they are the same but thanks any way.
door
hello. i am at the moment planning on doing such a mod using 2 batteries as i cant seem to get a hdd caddy working
ill post a new post once succes/failure arises
1 Opmerking:
Physically fitting a battery is the easy part (still not that easy) the hard part is how you connect it to the logic boards power connections without blowing the logic. Without a complete redesign of the logic its just not possible.
door
Voeg je antwoord toe
afendi27 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 7,422
