Ga door naar hoofdinhoud
The Epson Stylus Photo R2400 is a color inkjet photo printer made by Epson and marketed towards photography enthusiasts and professionals.
8 Vragen Bekijk alle
Roller paper is jammed
After printing a banner, and following manual instructions, I cut the paper before trying to back the paper out. Once before I cut the paper behind and pulled the paper out the front, but this time, against my better instincts, forgot since the manual says it will roll out the back.
The paper now refuses to back all the way out, and is stuck under immovable gears. When the printer was under warranty I had to replace the printer in a similar jam. Is dismantling the machine truly the only way to free the paper?
Is dit een goede vraag?
Score 1
1 Opmerking
Thanks, Ralph, for the tip on the manual. I'll get back to you if I'm smart enough to find the answer.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Here is the URL to download the service manual for this unit. Hope it helps. Ralph
http://online.manualspace.com/computer-p...
Was dit antwoord nuttig?
Score 2
1 Opmerking:
research +
door
Voeg je antwoord toe
Keith Fahey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,524
