Ga door naar hoofdinhoud
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Vragen Bekijk alle
Vraag afgerond
Time stamp on apps is different from my MBP
MacBook Pro 15" (v5.3) Unibody Mid 2009
Hello,
First, I'm sorry for my bad english and hope you can understand me.
Some months ago, my MBP started to show the wrong time, one hour into the future, although the automatic (apples european timeserver) adjustment is active in system-adjustments.
I have changed it manually, now when i get messages in iMessage or in Safari (facebook) the timestamp is shown the time one hour in the past. --> my time 14:00 but in fb 13:00.
Is this a cmos battery problem?
please help me, i don't know what to do... :(
best regards...
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Yes your CMOS battery needs replacing. Heres the iFixIt guide on the steps to get to it MBP "15 Core 2
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
thank you for your answer :)
bute i have a, maybe stupid ask, can you show on a photo for my mbp? because it is a little bit different.
i have the A1286 --> Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
MacBook Pro 15" Unibody Mid 2009
i'm not able to find where i can change the cmos-battery.
best regards
door
Sorry I jumped the gun here. Your system doesn't have a CMOS battery. Check your time zone settings. Make sure it's correct, then manually set the date & time (make sure your not connected to the network in any way). Once you have the Zone, Date & Time correctly set restart your system and then connect to the network it should stay at the correct settings now.
door
Het nuttigste antwoord
Go to System preference > Date & Time > Time Zone and reselect your correct zone.
Score 2
2 opmerkingen:
Thank you both for the answers. i could not try it, because i'm ill. i will do it some days later...
best regards
door
Hi,
thank you for your help. it seems that it helps. the time and the timestamp are now the same. i hope it will stay so...
best regards :)
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 191
