Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
what's the piece above wifi antenna for?
The piece fell off when i was removing the screw next to it. i was wondering what it was for.
http://smg.beta.photobucket.com/user/big...
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Danny, that is FL10_RF a 2.45GHZ-1.8DB 0805 Band Pass Filter and the muRata LFB182G45SG9B740 should work. Check the datasheet right here. It is a readily available part on here. Check the datasheet for the dimension. To replace it you will need some good tools and definitely a steady hand and a good magnification source.Hope this helps, good luck.
Was dit antwoord nuttig?
2 opmerkingen:
Yes this helps, and thank you for telling me where i can order one, just one more question what does it do? I'm assuming it has to do with the WIFI or bluetooth but i'm not sure.
door
Fanny, than you for accepting my answer. The band pass filter most likely helps to look for correct signals by filtering out unwanted frequencies. That would be the most common reason for it to be within this circuit. There are other things that they can do, depending on the circuit they are used with.
door
Voeg je antwoord toe
Danny zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 726
