Ga door naar hoofdinhoud
Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
Vraag afgerond
Can you cut one set of wires?
My floor lamp has five arms resulting in 10 wires, can I cut one set of wires and cap (one arm has faulty base)?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Yes but you must cap/insulate each end of the pair you cut.
If this Answer is helpful please remember to return and mark it Accepted.
Was dit antwoord nuttig?
Score 2
I can confirm previous answer.Its not necessary but if possible also is good to check for grounding,or short circuit..
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 264
