Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
20 Vragen Bekijk alle
How do I reset my iPhone 3G?
I was trying to download some programs on my iphone over the internet, and my phone went off. Now when I turn it on, all I get is the apple on the screen and nothing else. How do I reset my iphone 3G?
Is dit een goede vraag?
Score 10
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
You'll need to connect the phone to iTunes then, do the following;
Hold down the sleep/wake button (top button) and the home button (round button) at the same time until your device turns off. Release the sleep/wake button but, continue to hold down the home button. You should see a notification from iTunes indicating it has found a device in recovery mode. Then you simply click on the restore button in iTunes. This should resolve th issue. Hope this is helpful.
Was dit antwoord nuttig?
Score 6
Hi!
First, try turning off your iPhone, and powering it back on. This probably won't work.
Second, Try Recovery mode.
(Recovery mode erases your device and restores it, which should resolve the issue. If you previously synced with iTunes or iCloud, you may be able to restore from your backup after recovery.
1. Turn off your device. If you can't turn it off, press and hold the Sleep/Wake and Home buttons at the same time and wait a few seconds for it to turn off.
2. Plug the device's USB cable into your computer only.
3. Hold down the device's Home button as you connect the USB cable to it.
4. When you see the Connect to iTunes screen, release the Home button. If you don't see this screen, try steps 1 through 3 one more time.
iTunes should open and display a message such as: "iTunes has detected an iPhone in recovery mode. You must restore this iPhone before it can be used with iTunes."
5. Use iTunes to restore your device.
Third, Try DFU mode.
How to enter DFU mode:
1. Plug your device into your computer
2. Turn off the device by holding the Sleep/Wake or Power button and swiping it off
3.Hold the power button for 3 seconds
4.Begin holding the Home button without releasing the Sleep/Power button for 10 seconds
5.Release the power button and continue holding the home button until you get a popup from iTunes that your device is recognized as being in recovery mode.
If this helped or you found this answer useful, please 'accept' or click the up arrow :)
Score 6
1 Opmerking:
didn't work cannot get into DFU Mode!
door
iphone a1387 netwark unlok
Score -1
I had a question I got an 1 st. Genie iPhone but the issue it’s to me wird because on screen appears insert sim to act but I did already the slot reads the sim but istill I cant have access to menu then on lock or wallpaper screens behind shows connect to I tunes so if I do could be work or some dameges on soft
Score -1
1 Opmerking:
Ummmm....WHAT???
door
Voeg je antwoord toe
christinaguffey71 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 34
Altijd: 18,744
