Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Vraag afgerond
Replaced Dock Connector, Speaker not working.
I just replaced an iPhone 4S Dock Connector with iFixit parts. Everything seems to be working except the speaker. No music or speakerphone output. Charging works, microphone works.
Before I tear into it again, is this likely a loose connector or a defective dock connector or something else?
Thanks.
Is dit een goede vraag?
1 Opmerking
The speaker suddenly began to work which suggests there is a pin alignment or connector issue but I won't open it again until the problem reoccurs. Thanks for the detailed reply.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Check to see if the Dock Flex Cable Connector is perfectly down on Logic Board Connector. If OK, then check the two contact points on the new Dock Flex Cable are making perfect contact with the two pins on the Dock Speaker Assembly. Make sure the Dock Speaker Assembly is screwed down correctly. If still a problem, either the new Dock Flex is bad or the Speaker Assembly is bad.
Was dit antwoord nuttig?
Score 2
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 625
