Ga door naar hoofdinhoud
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
Is a broken LCD connector fixable?
I screwed up bit time with my mother's Imac 27 late 2009. The superdrive was broken and making unbearable noises. Plus there was the flickering screen problem. So I decided to tear the Imac down and remove the superdrive. While putting the mac back together, I broke the LCD connector on what I think is the logic board....
Is there something to do else than replacing the whole board?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Not that you could DIY Repair of logic boards require special tools, solder and lots & lots of practice. You might contact local computer repair/building shops - they could have the tools and experience. If not a complete logic board replacement is called for (you might want a professional to do that since it is advanced DIY repair)
If this Answer is helpful please remember to return and mark it Accepted.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Alex Lepan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 414
