Optical drive bezel screws
Step 27.
Re. three 4.5 Philips along the Optical drive bezel. If put in block the disc entering the drive !
i. What am I doing wrong?
ii. These screws do not appear to be doing any thing !
Please help. Thank you.
Update
Thank you Ralph.I have tried 3mm as well as 4mm screws but no difference.The problem seems to be even worse. I just put this iBook together and I am using it now for this.I had left the three screws out, but still can not get the disc in.
It appears that something on the front side at the same place where the third screw should have been there is a blockage.
I am a touch miffed at the moment although I had tried the disc before I put it all together !!
Any advice/suggestion will be appreciated.
Is dit een goede vraag?
