Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Vraag afgerond
Can I repair/replace the motherboard of iPhone 4s?
My Iphone 4s motherboard got water damaged & cannot be repaired in Kuwait.So I just wanted to know that is it possible to repair/replace the motherboard elsewhere in the world,specially in US & how much will it cost?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I have never found a way to do that cheaper than finding a used working phone, I am surprised that the water damage cant be fixed, I have the best fix success rate with the Iphone compared to any other phone, it must have went in salt water, maybe take it to a different shop or use the Guides on here and try fixing it yourself, good luck, If this Answer is helpful please remember to return and mark it Accepted.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Dear Mitch Rush,
Thanks for spending time to reply me.I took the phone to 3 different shops & all the 3 said about the mother board.Please let me know that the mother board can be repaired in US& also how much will it cost?(I don't want to just throw away my phone as its new!!!!!)
door
With water damage there is never a guarantee that it will fix your phone, most shops don't charge very much for the treatment and is well worth the risk if you don't want to fix it your self, there are guides on here to step you through it, unless your phone was in salt water or it has been a year since it was submerged there is a real good chance it can be fixed if it's put through the right steps, good luck.
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,295
