Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
583 Vragen Bekijk alle
Can I Install an SDD and keep the original HDD
Can I Install an SDD and keep the original HDD in my Macbook pro and then move the operating system from the HDD to the new SDD, so in this way ill be able to use the SDD for OS running and boot and the HDD for storage.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
No and yes. NO if you want to retain use of your optical drive, there physically isn't enough room in the machine for two hard drives in addition to your SuperDrive. YES if you don't mid losing your SuperDrive in favor of a second hard drive.
The kit below allows this exact setup by providing a hard drive carrier in the shape of an optical drive that mounts where the SuperDrive once was, allowing you to instead install the secondary hard drive.
SATA Optical Bay Hard Drive Enclosure Kit
Once that is installed you can format and setup the drives in whatever configuration you choose.
Unibody Laptop Dual Drive Afbeelding
Product
$24.99
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Mohamad Hakim Kharboutli zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 734
