One day I noticed the heater would not produce any heat, not matter what the position of the thermostat.
It turned out the thermostat cable tied to the knob was disconnected behind the console.
Apparently this is a fairly common problem with this car and garages love it because it can be made to look like an expensive repair, such as A/C replacement, etc.
Instead I fixed it with just a couple screwdrivers and a little bit of time.
There's a lot of plastic covers to remove but in the end, I could find the connector that was indeed disconnected. It plugs up, so I suspect after 15 years, it slowly nudged itself down via gravity and vibrations.
Even though it's somewhat difficult to access with your fingers, I was able to plug it back up.
Works like a charm now!
Long story short, I compiled the few videos that helped me remove the plastic covers in order to get access to the console. Counter-intuitively, you have to start from the back seat to remove the center console and work your way towards the front.
Then follow the cable that connects the thermostat and the other end might be dislodged just enough that it cannot control the heater anymore.
https://youtu.be/7mR6mH3ZlOI
https://youtu.be/5Od5pg1KxLw
https://youtu.be/K_k5MFC2wMQ
What model Jetta is it and what engine does it have?
door oldturkey03
it is a 2001 volkswagen jetta gls 2.0L 4 door sedan
door josue villarreal
Probably it's broken and you have to fix it.
door Politers
good answers
door Rebinas
Is it the same for a 2003. My defrost works good, I feel heat with it but not heater. I was going to see about getting new coil but the price to get done. I'd rather check first. What do I do?
door Stephanie Jones (Phe)
2 commentaren meer tonen
