Ga door naar hoofdinhoud
De huidige lijn van iPod Nanos bestaat uit 7 verschillende generaties.
1006 Vragen Bekijk alle
Why is my iPod nano screen frozen?
I was downloading music into my iPod, and now the screen is frozen! It won't let me clear it, turn it off, nothing! Please help!
Is dit een goede vraag?
Score 1
1 Opmerking
What generation of ipod is it?
door
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
hard to say - can you see it in iTunes? can you do a restore?
Once the battery has run down it will switch itself off - give it a few days. Maybe after that connecting it to a charging source will sort all out
Was dit antwoord nuttig?
Score 1
It's perhaps a software bug? So, I suggest you follow these instruction from Apple to reset your iPod.
Learn how to reset or restart iPod following a freeze. Tip: Check out this helpful movie too.
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
If the iPod is connected to a computer and displays any of the following messages you should eject the iPod from within iTunes instead of resetting it:
  • Connected. Eject before disconnecting
  • Sync in Progress. Please wait...
  • Do not disconnect
If your iPod is frozen or won't turn on, the steps to reset it vary by model. You caneasily tell which iPod model you have if you're not sure.
Score 1
screen is freeze, cant turn it off
screen is freeze, can`t turn it off
hold down the center button and the menu button at the same time and that will reset it.
Voeg je antwoord toe
anniedubs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 2,987
