Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Vraag afgerond
What causes the battery to go dead shortly after a recharge?
Most of the time the battery will last the whole day, but sometimes I will fully charge it and the phone will not turn just a couple hours later, so I plug it in until it finally comes on. Could it be the battery or possibly something else?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Battery's tend to die off slowly with daily consistency, If I were you I would look into Battery killing Apps or something else being on when you have shortened Battery cycles, if you keep having this problem then I would replace the Battery, good luck, If this Answer is helpful please remember to return and mark it Accepted.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 351
