Ga door naar hoofdinhoud
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
20 Vragen Bekijk alle
laptop says plugged in but not charging.
This problem started 3 months ago, all I had to do was unplug it and then plug it back in and it would charge fine. Now nothing works it just says "pluged in (not charging)" now.
Is dit een goede vraag?
Score 5
1 Opmerking
Use this : Dell AC Adapter LA90PM130
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
This could be an indication that the battery wont hold a charge. Might need to replace the battery
Was dit antwoord nuttig?
It seems like you battery is expired because usually laptop`s battery last for 1 to 2 in normal form. So if your laptop is a year or two older then you would defiantly need to replace the batter and make sure to order the proper OEM replacement battery because other aftermarket ones wont give you very good output.
1 Opmerking:
I was change a battery last week but still plugged in not charging
door
Voeg je antwoord toe
Andy Lamb zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 1,594
