Ga door naar hoofdinhoud
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Vragen Bekijk alle
Vraag afgerond
Broken display cable socket and pull tab
While removing the display cable connector from the socket, I made the mistake of pulling it up, not straight away. As a result, the pull tab came off from the connector and the small copper bridge on top of the socket popped loose on one side. Of course, now the display doesn't work.
My question is whether the copper piece is soldered in place so that I can simply tack it back down. I can get the connector back into the socket okay, even without the pull tab attached.
I think the connector and socket are otherwise not damaged.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Yes they are soldered... however... soldering logic boards is beyond most DIY. It requires special tools, solder, and lots & lots of practice.
If this Answer is helpful please remember to return and mark it Accepted.
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 319
