Ga door naar hoofdinhoud
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
Bypass Power Button To Check Logic Board?
My friend dropped cream on my macbook pro.
The magsafe is giving the green light.
When I press the power button it does not start.
Is there any pads I can short to check if the logic board in turning on.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Yes there are... You realize you can blow the logic board forcing power up if the board is not completely clean and dry? They have not moved since the answer to this Question.
If this answer was helpful please remember to mark it accepted.''
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
I have tried those pads but no luck, I have disassembled the logicboard, I am getting a green light from the magsafe the fans are connected but it does not turn on.
There was some oxidation near the keyboard connector, I cleaned it with a brush.
How do you clean liquid damaged logic boards ?
door
There's a whole set of advice... soft to medium brushes, dielectric contact cleaner, 99% alcohol... let it dry well (low humidity - 72 hrs)... look for a (i) power on symbol near the contacts or it may say prbn... bridging between contact #5 & #6 on the top case ribbon connector may work.
door
Voeg je antwoord toe
mbaig zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,669
