Ga door naar hoofdinhoud
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
20 Vragen Bekijk alle
Why won't my sterio work?but did before?
i put a cd player in my car before and switched it out for a newer cd player.now that i put a new one in it won't work.i double checked to make sure all wires where right and fuses...What else could it be for it not to work?
Is dit een goede vraag?
Score 1
2 opmerkingen
Is it an aftermarket stereo or a Toyota brand? Do you use an amp with it? What was the issue with the old one? You just replaced it to go with a newer player?
door
i just replaced the stereo for a newer one. there is no amp connected.ok i will check the wires again..thank u both very much
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
First thing I would do is test the power wire to the stereo with a volt meter and see if you are getting 12 volts from it and at the same time make sure the Ground source is also working, if that is good I would look for a fuse that is in the stereo itself and see if it's good, if that's all good then I would have to think the stereo may be bad.
Was dit antwoord nuttig?
Voeg je antwoord toe
gamesnotwar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 407
