Ga door naar hoofdinhoud
Model A1046 or A1095 / 1280x854 screen resolution
118 Vragen Bekijk alle
Starts only with command key pressed down.
My laptop does only starts when the command key is pressed for about fifthteen sec. when starting the machine.
There is a discussion about this problem:
http://discussions.info.apple.com/thread...
I tried everything that seems possible, incl. all the tips discussed in the Link (above). BUt still.
When i press the command key while starting the machine everything is fine, but if not, the machine goes out, as described in above discussion.
Thank you for any suggestion that could help me solving this problem
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Here is a list of all keyboard Mac commands: http://homepage.mac.com/frakes/MOSXPT/co...
As you can see the Command only key is not listed. It is a modifier key. Personally I would reinstall the system. What is the history of this machine? Does it use a foreign keyboard?
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
mamali zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 1,199
