Ga door naar hoofdinhoud
web cam for iBook g4 1.33
Hey there. I tried to connect regular window's webcam , it didnt work. So tell me , please, do i need some special web cam or i do something wrong in connection?
thank you . Mike
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Your best bet for compatibility is a used Firewire 400 iSight. These are not hard to come by despite being long discontinued.
If you do not wish to get a used camera, most USB webcams work with OS X without explicitly saying it, but they may be few and far between. Try and find one that's advertised to work otherwise make sure it comes from a store with a solid return policy as insurance.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
The Macally IceCam2 webcam works pretty well with my daughter's iBook G4 1.33Ghz under OSX 10.5.8. It's a USB 2.0 webcam so it won't work with Macs using the old USB 1.0 technology.
http://www.macally.com/en/product/Articl...
Score 3
To use iChat (or any other video chating software), you need a FireWire 400 webcam (Preferably an Apple iSight) and a FireWire 400 port (Which your laptop should have). External USB webcams are not supported in Mac OS X.
Score 1
1 Opmerking:
thank you :)
door
Any webcam that is UVC (USB Video Compliant) should work. You will need to be using at least OS 10.4.9. Personally I use a Logitech, QuickCam Deluxe for Notebooks, and it works fine. But be carefully, older versions of the Deluxe model do not support UVC. Look for a model that is VISTA compliant, that should also be UVC compiant. You may want to pick up a copy of iGlasses, the software will give you a lot of control over the webcam image.
Voeg je antwoord toe
mike zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 4,549
