Ga door naar hoofdinhoud
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Vragen Bekijk alle
Magsafe 2 Adapter Teardown for Key ring
Hey there,
anyone of you already took a MagSafe 2 to MagSafe adapter apart? Would like to have one at my key ring - so need to drill a hole through - I assume at the border in a 45° angle it would work. Anyway it would be interesting to see a teardown of the little magnet.
Some inputs?
Best regards
Mg
Is dit een goede vraag?
Score 2
1 Opmerking
Thanks! Nice to know people like you exist ;)
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Turns out theres a product that addresses this need. I'm not affiliated with the maker in any way, just happened to remember this question as I saw this pop up in my news feed...
Magsafe -> Magsafe 2 keyring
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
It is not easy to find an answer. Because you or somebody should sacrifice his adapter:) It's a recent thing and not easily break.
But I have an idea. Clip a cable-tie horizontally to your adapter. Cut the tie end a little longer enough to drill and hang to your key-ring. a 5 mm tie width with a 2 mm hole would be good for the purpose. I cannot add a photo but cable-tie holds the device firm enough. Maybe a drop of proper type of glue will secure more.
If you don't like it, nothing is harmed than a cable-tie!
Score 1
Voeg je antwoord toe
mailgoe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 2,484
