The temperature always show overheated
The temperature shows at 50 Celsius degree when turning on so it turn off soon automatically.
Many thanks!
Personal point of view:
I suspect it is due to the malfunction of the temperature sensor. But I don't know what it look like and where to get. Is it possible to be replaced or fix by myself?
Is dit een goede vraag?
Score
0
Temp sensor is a black bead (NTC) inside a small white plastic box attached to the back cooling radiator.
If you can not get one, replace it with a 10k ohm resistor, it will show 24C always but will still work ok if its dehumidification you want.
Parksy
door parksy1234
