Ga door naar hoofdinhoud
Model A1285 / 8 or 16 GB capacity
206 Vragen Bekijk alle
Vraag afgerond
Problem of screen which becomes quite white
Hello, I have an iPod nano. I can listen to musics with but the screen does not walk any more.IT is all white. At first there was only some white line on the screen and now I see nothing more. What is what you know where from that could come? I have thought in of condenser but me does not follow it on and I would like to know before defusing it.
Thank you very much.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
First, try restoring it with iTunes.
If that doesn't help, try replacing the LCD screen.
If it still has problems (hopefully not), then it is probably a bad motherboard.
Was dit antwoord nuttig?
1 Opmerking:
I am going to try. The restoration with itune did not walk. I am thus going to unsettle and to replace the screen. I had thought of a problem of condenser which did not walk any more (I saw that on computer screen there was often this problem). What is that that could come from there?
Thank you very much
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 809
