Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Vragen Bekijk alle
Vraag afgerond
Weak wifi reception comparing to my other iPhone 4
I recently bought a second hand iphone 4 and noticed its wifi reception is poor. Opened it up tightened the screws (tiny metal part on antenna plate is still there) but still the reception remains poor. The antenna plate screw (1.6 mm philips) next to camera flash is missing. Would that be the cause ? If not what would you suggest. Thank you
Is dit een goede vraag?
2 opmerkingen:
I believe the wifi antenna is the metal plate or am I wrong.
door
So does anyone know if the 1.6 mm philips screw next to camera flash, affects the wifi reception ?
door
Voeg een opmerking toe
2 Antwoorden
check the antenna below... There are 4 "clips" they have to be between the speaker and midframe. You have to change if 1 of them is broken. And on top you have a metal piece from mothboard that have to touch the frame. (something diffrent then the EIM shield)
Was dit antwoord nuttig?
I just put the earphones on and suddenly wifi works perfectly. Took them off, very weak reception. Does anyone know if that 1.6mm screw is the reason ?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 795
