Ga door naar hoofdinhoud
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
How can I completely remove the screen?
I want to remove the screen from my PowerBook G4 so I can use the base as a computer attached to my TV without any loss of functionality (I understand Airport and the Bluetooth antennas are connected to the screen?) All help appreciated!
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I would follow the directions for removal of the LCD screen first as described here: PowerBook G4 Aluminum 17" 1-1.67 GHz Display Replacement
Then you should be able to remove the hinges.
Was dit antwoord nuttig?
Score 2
You can separate your display assembly from your bottom case using the link mayer posted in his answer then open the display and remove the airport/bluethoot antenna cable. Simply reconnect the cable to your logic board and you will restore the wireless functionality.
Score 2
Voeg je antwoord toe
Dave Robertson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,301
