Thank you all for sharing these tips; yes, this also resolved my problem: the wire connecting the negative pole of the battery was torn, i.e. as it was attached to the spring on the battery compartment door and yes, it's a DESIGN FAILURE to have this tiny and very weak wire soldered to the end-point on the door. Of course, it broke as per the 'paper-clip repeated bending' analogy shared above already.
I don't have soldering equipment at home, so had to improvise to fix as follows:
1/ Very gently peel the wire-casing to expose the metal wire inside, I had to remove the door to more easily reach this tiny wire
2/ Make a 'cap' with aluminium foil to cover the battery's negative pole: this cap should reach half-way through the battery, such that when it's in place it can make contact with the exposed wire
3/ Re-attach the door and close it, to ensure the exposed wire touches the aluminium cap, you should keep inserting extra bits of aluminium folds until the closed-door presses the wire against the aluminium cap that covers the batter.
It brought my headset back to life! It works. Just need aluminium foil. I will complain to Bose about this, too, very predictable failure point.
23 opmerkingen
I noticed you never got an answer to this. Are you still having this problem
door originalmachead
I have owned Bose Quiet Comfort Headphones since 2001. My experience is that if you are out of warranty, it is worth the $100 for the repair. They usually will send you a refurbished set identical to your current model. And it has a one year warranty on them. One time, my replacement set developed the same issue as the original in about six months, and they sent me a brand new set of the next generation QC at no cost.
door lynwoodbrawn
They repaired my QC2s for $50 in 2011. Well Worth it. I removed my earpads before mailing it in so now I have a backup pair for future repairs and/or a dry pair after working hard in them.
door tlf89
I had this same problem. I had corrosion from the battery which caused the problem. It took a little but a removed as much of the white powder with a box cutter and finally worked again.
door tyoung406307
Ditto on hard-to-see corrosion after leaving battery in for extended time and not using the headphones. A damp (not soaking) ear swab with white vinegar carefully rubbed on the interior positive contact, then drying with another dry swab and optionally using a hair dryer to assure evaporating any remaining solution, cured what was an issue of a bad contact. Of course replace the battery which was the cause of the corrosion. All is good again.
door gjkollar
18 commentaren meer tonen
