Ga door naar hoofdinhoud
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
313 Vragen Bekijk alle
Screen's hinges are loosened
Hello Everybody,
I'm writing this post because my screen's hinges are loosened, the screen don't close by itself but it move on its axis. I just want to know if i can tighten it. May be by tighten a screw or something, like on the DELL laptop, or I have to change the hinges?
Thanks in advance for all answers.
Best,
Arnaud
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Apple has recognized that this is a defect. If the loose hinge gives more than an inch of play, they'll replace it for free -- even if the computer is out of warranty. Here's the link to the official Apple page on the subject: http://support.apple.com/kb/TS2948
From what I've read online, repairing it yourself is a pretty expensive proposition -- as I recall, you can't just tighten the hinge; you have to replace the whole screen.
Was dit antwoord nuttig?
Score 4
I have the same problem. I followed the link, spoke with apple support, then found out that this no cost repair is for MacBook Air's only.
1 Opmerking:
msjunk, it is probably best if you ask your own question. this one here seems to be a bit old (2years) and it does not look like it is visited often:-) Click on this link and give as much detail as possible. Good Luck.
door
usually hinges over the time get loose because the times you open and close the screen you can go to peachmac or apple store to get it tighten.
Voeg je antwoord toe
Arnaud zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 14,604
